www.bgaudio.org :: Преглед на тема - Хорна с BG-20
Хорна с BG-20
Иди на страница Предишна  1, 2, 3, 4
Регистриран на: Sep 11, 2004
МнениеПуснато на: Вто Ное 11, 2008 4:37 pm    Заглавие: Отговорете с цитат
Очень вероятно, что ентусиаст по русски ничего не понимает Smile
Inspiration Audio
IDS AG
entusiast
Регистриран на: Jan 04, 2008
Местожителство: Пловдив
МнениеПуснато на: Сря Ное 12, 2008 10:19 am    Заглавие: Отговорете с цитат
Hi Andrei,
My horns with BG20 where changed so many times,that I forgot what i did with it anyway.The cause of those changes was tne unpleasant sound who this driver makes at all.So,my friendly advice to you is to make for your BG20-s some BR or sealed enclosure,if you want to have good horns find some other driver Wink .This is my personal oppinion,bassed on my personal expirience with BG20.
Do not confuse movement with action!
AviRad
Регистриран на: Apr 09, 2007
Местожителство: Горна Оряховица, България
МнениеПуснато на: Сря Ное 12, 2008 10:42 am    Заглавие: Отговорете с цитат
Andrei написа:
Подожду ещё неделю-вторую. Потом буду собирать "1m BL-HORN" по чертежам geist4711 в чистом виде.
I see that you've not started building that horn yet. Thanks, lord!
Please, do not use the geist4711 project. "1m BL-HORN" is meant to be a rear speaker in a home theater system. So do not expect any descent low frequencies. There are a lot of resonances and peaks, but it's normal for a 1m horn. My personal opinion is that geist4711 horns should be forbidden with law Wink I believe that there are a lot of beginner enthusiasts (like me) that have build those projects and are not satisfied with the results.
My final version of this horn is:
- volume of the compression chamber is 9 l; filled with sand;
- throat area is 180 sq.cm; plywood board with smaller hole in it;
, and it still doesn't sound like a real horn should.
My advice: calculate a horn yourself or find another project (not geist4711);
p.s. - sorry, I don't speak Russian
Andrei
Регистриран на: Nov 09, 2008
МнениеПуснато на: Сря Ное 12, 2008 12:00 pm    Заглавие: Отговорете с цитат
Спасибо большое всем, кто помог
Теперь буду думать, что же делать с готовыми панелями по чертежам "1mBL-HORN".
Фанера уже нарезана, но ящики ещё не сделаны.
Пошел пить водку.... и делать закрытый ящик в 30L для bg20, как советует Visaton Smile
Спасибо ещё раз.
Many thanks to all who has helped
Now I will think what to do with ready panels under "1mBL-HORN".
Plywood is already cut, but boxes are not made yet.
Has gone to drink vodka... and to do the closed box in 30L for bg20 as recommends Visaton:)
Thanks 4ALL
МнениеПуснато на: Сря Ное 12, 2008 1:30 pm    Заглавие: Отговорете с цитат
Друг, пиши только по русски, инглиш для тех, которые на нашу кирилицу не понимают Smile
Inspiration Audio
IDS AG
AviRad
МнениеПуснато на: Сря Ное 12, 2008 2:21 pm    Заглавие: Отговорете с цитат
Я понимаю все Smile Я просто не могу писать на русском языке.
entusiast
МнениеПуснато на: Сря Ное 12, 2008 3:27 pm    Заглавие: Отговорете с цитат
AviRad написа:
Я тоже Smile
Andrei
МнениеПуснато на: Чет Ное 13, 2008 10:13 am    Заглавие: Отговорете с цитат
Спасибо, друзья!
Получается, что bg20 в исполнении HORN - ничего хорошего. Понял.
Ну что же делать? Динамики куплены, фанера нарезана.
Кто-нибудь из вас делал 100-литровый ящик на bg20 с хорошим (для bg20 Smile ) звуком , что можно порекомендовать мне с учетом готовых заготовок из хорошей фанеры, т.е 26х38х98 см внутреннего объёма ?
Усилитель ламповый однотактный на EL34
Менять динамики на другие пока нет возможности.
Сейчас рассматриваю вариант фазоинвертора
http://audio.goldprivacy.com/docs/bg20_ak.jpg
с сайта http://audio.goldprivacy.com/index.php?articl=132&button=Button2
- очень близко к моим готовым размерам.
Прошу прощения у модераторов, я понимаю что ветка HORN bg20.
Можно в pm или на e-mail. Спасибо.
AviRad
МнениеПуснато на: Чет Ное 13, 2008 2:25 pm    Заглавие: Отговорете с цитат
Andrei,
I think that it's still possible for you to calculate another contour for the horn and fit it in the original project dimensions.
Do not throw away the whole idea of BG20 and horns. It is a good speaker to start with.
Here is an example:
Just do some minor calculations and with a few changes you can make the horn longer (better). Read http://bgaudio.org/modules.php?name=Forums&file=viewtopic&t=4468 for further information.
Try with 7-8l chamber and ~ 190 sq. cm throat.
Страница 4 от 4
Генериране на страницата: 0.46 секунди
