www.bgaudio.org :: Преглед на тема - Technics SH 8065 EQ 2x33 band
Ivan Rachev
Регистриран на: Aug 04, 2004
МнениеПуснато на: Сря Мар 04, 2009 9:43 am    Заглавие: Technics SH 8065 EQ 2x33 band Отговорете с цитат
Technical Specifications:
- 33 bands per channel
- 1/3 Octave Bandwidth
- 1V / 150mV Utility Gain Switch
- 0.0025% THD
- 110dB Signal-to-Noise Ratio
- ± 12dB Boost / Cut Range
- EQ on/bypass switch
- Tape Monitor on/off switch
- Variable range ±12dB/±3dB swtch (setting it to ±12dB lets you utilise the complete boost/cut range, whereas setting it to ±3dB imposes a limiter on the current boost/cut settings so that none exceed ±3dB)
- Rec EQ/bypass switch
- Characteristic Normal/Reverse switch (setting it to normal outputs the signal as you have set the sliders, whereas setting it to reverse creates a vertical mirror image of the current pattern of the sliders giving the opposite effect).
The frequency sliders are SEPARATE for each channel and are set at:
16Hz, 20Hz, 25Hz, 31.5Hz, 40Hz, 50Hz, 63Hz, 80Hz, 100Hz, 125Hz, 160Hz, 200Hz, 250Hz, 315Hz, 400Hz, 500Hz, 630Hz, 800Hz, 1kHz, 1.25kHz, 1.6kHz, 2kHz, 2.5kHz, 3.15kHz, 4kHz, 5kHz, 6.3kHz, 8kHz, 10kHz, 12.5kHz, 16kHz, 20kHz, 25kHz
Inputs/Outputs on rear:
- L&R RCA Line In
- L&R RCA Line Out
- L&R Tape In (Playback)
- L&R Tape Out (Record)
- DIN Tape In/Out (if you have an older tape machine)
- 1V / 150mV utility gain switch (as mentioned above) (should be set 1V if you have a powerful input signal and should be set to 150mV if you have a weak input signal. As most signals nowadays are at line levels I just leve it set to 1V all the time to ensure ample headroom and it sounds fine for everything)
- Multivoltage selector - 110v/120v/220v/240v
- Dimensions: 16.75 inches wide, 12.5 inches deep, 5.75 inches high
http://articulo.mercadolibre.cl/MLC-10411382-unico-ecualizador-technics-sh-8065-33-bandas-por-canal--_JM някои от върховете на плъзгачите са отчупени , всичко работи 200 лв
Etheraudio
BGaudio
Metropolisaudio
Министерство на Звука
.......срещу ми мишки църкат
като ме видят , познай къде си бъркат.
Генериране на страницата: 0.28 секунди
