Ето ти малко инфо: (ПРАТИЛ СЪМ ТИ СЕРВИЗНО ОПИСАНИЕ НА e-maila)Destination AEP
Description INTEGRATED STEREO AMPLIFIER
1993
Power requirements 220 - 230 Vac ( 50/60 Hz )
Power consumption 230 W ( GE + EUROPE )
Power consumption 180 W ( SCAND.,SWISS,SP,PORTUGAL )
Depth 375 mm
Width 430 mm
Height 150 mm
Weight 9.7 kg
Supplied Accessories REMOCON RMS311
Phono MM Input PHONO JACK
Phono MM Input 2.0 mV ( IMP. 50 kohm )
Phono MC Input PHONO JACK
Phono MC Input 0.25 mV ( IMP. 100 ohm )
Line Input PHONO JACK
Line Input 150 mV ( IMP. 50 kohm )
Line Output PHONO JACK
Line Output 150 mV ( IMP. 1 kohm )
Speaker Output 8 - 16 ohm ( SCAND.,SWISS,SP,PORTUGAL )
Speaker Output 4 - 16 ohm ( OTHER )
Headphones Output STEREOPHONE JACK ( LOW + HIGH IMP. )
Phono MM Frequency response RIAA EQUALIZATION CURVE,±0.5 dB
Line Frequency response 7 - 100000 Hz ( +0/-3 dB )
Phono MM S/N ratio 94 dB
Phono MC S/N ratio 76 dB
Line S/N ratio 103 dB
Residual noise <170 µV ( NETWORK A )
THD <0.008 % ( 10 W )
TIM <0.008 % ( 10 W )
Output power 110 + 110 W ( IMP. 4 ohm,GE )
Output power 90 + 90 W ( IMP. 8 ohm,GE )
Output power 80 + 80 W ( IMP. 4 ohm,GE + OTHER )
Output power 75 + 75 W ( IMP. 8 ohm,GE + OTHER )
Output power 85 + 85 W ( IMP. 8 ohm,SCAND.,SWISS )
Output power 70 + 70 W ( IMP. 8 ohm,SCAND.,SWISS )
Output power 110 + 110 W ( IMP. 4 ohm,OTHER )
Output power 90 + 90 W ( IMP. 8 ohm,OTHER )
Damping factor 70 ( IMP. 8 ohm )
Bass Tone control ±7 dB ( RESPONSE,300 Hz )
Treble Tone control ±6 dB ( RESPONSE,5 kHz )
Регистриран на: Apr 15, 2005 Мнения: 134 Местожителство: Стара Загора
Пуснато на: Пон Юни 26, 2006 10:40 pm Заглавие:
Благодаря за инфото а това СЕРВИЗНО ОПИСАНИЕ ще можеш ли пак да го пратиш, че нещо може и да съм го изтрил по погрешка като съм видял, че е от непознат
